Where is the power loss?
bob123131
457
Dec 20, 2004
winona, Minnesota
Ok so i was driving and my car just started kinda sputtering and i couldnt rev past 2500 rpms. After i got home and had to drive 30 on freeway the hole way ifigured out my lower ic pipe and literally come loose from my ic no idea why. I fixed this and tightend it and yet i can stil lfeel a lack of power. I did a boost leak test but couldnt hear any other leaks. I had a friend drive it around block and as they pulled away i could hear a whooosh it sounded like engine was gasping for air or i had a huge leak. Is there anythign that this could be besides boost leak. My mpg went down alos so i replaced fuel filter no change. I cant here this noise when i rev it only when the car is moving and im out side of it. Any ideas what to try or maybe a problem i could have caused driving home with ic pipe disconnected. My spark plugs had alot of carbon build up also when ic pipe disconnected.
The computer may be in "Safe Mode". Try to disconnect the battery for a few min.( abot 10). Reconect it then go hammer the shit out of your car. This is when the ECU goes thru a learning cycle. So if you hammer it, it will learn this setting and give you the optimum performance for this situation! :shhh: :dsm:
