Where is the Intake air temp sensor
The IAT sensor is incorporated into the 2G MAF, specifically pins 1 (green w/ yellow: 5V power supply), 5 (black: ground), and 6 (red w/ blue: the sensor itself).
As stated above, the IAT in a 2G is in the MAF unit itself wich can be misleading when logging on hot days or if you have alot of high underhood temps because the IAT will give the temp reading as soon as the air enters the MAF and if you have an efficiant intercooler, those temps are obviously going to be lower than what the MAF IAT is saying they are.
