Where is the fuel cutoff on a 1997 gst spyder?
Well lately, I've been working with this on my '97 GSX so I hope this helps.
In the engine bay, the fuse box has a 30A 'moteur' (nope, not a typo) fuse in it. For me, pulling this will turn off the main voltage pins going to the ECU pins 12 & 25. At the same time, it disables the fuel pump relay. I needed the ecu on but NOT the fuel pump (engine was out the car), so pulling that fuse wouldn't work for me. I traced some things and found there is the set of MPI relays behind the passenger left kick panel. The one with the red wires is for the ECU. However, the other relay is for the fuel pump. Just disconnect that. Or pull the 30A fuse, but you won't have the ECU.
Here's a pic:
The 2 relays are behind that brace there, held on with the 2 bolts seen in the pic.
See the problem is that the car will start, but won't turn over. After investigating a little bit I found that the fuel pump was not getting any juice to it at all. So do you think that replacing the fuel pump relay would fix that problem? I recently was working on this car a few months back and the pump was fine and it started right up. But now its not getting any juice to it and it has just set in one spot so it doesnt make much since
You should test the relay first as it may be expensive. Very simple.
And the ECU turns on the FP relay AS LONG AS it is receiving pulses from the cam sensor or when the key is first cycled to run.
You mean the car will crank but not start right?
PieEyedPiper, I was under the impression the rewired pump is still being controlled by the mfi relay hence ECU. I also have a rewire kit with relay next to the pump, but is still controlled by the mfi and - ultimately the ECU.
Correct with it will crank but wont start. I have a 98 spyder gst too so i'll swap the relay from it to my 97 and see if that works. I'm sure the relays are compatible correct? That would save me some hassle though of having to check other things or buy a new one if its not needed
I think you should check that fuse... If you can scan the car and see if it has codes. I am pretty sure if you have a cam or crank fault it would show up. Do you have a check engine light where you just turn the key on to Acc? The relay is in the middle of that circuit go to the beginning since you already tested the end of it. (fuel pump) What did you use to check for voltage at the fuel pump?
