Where does rear o2 sensor wiring meet harness?
Index420
Jul 20, 2006
New Milford, Connecticut
Im trying to track down where the rear o2 sensor connects to...Ive found a connector up by the fuse box in engine compartment...but that just seems like a stretch...Is this where it connects?? or should I look elsewhere...Would like to know before I start cuttin and soldering the wires...
PS its a 95 GSX 5spd if that matters...and im trying to undo all the hacking the previous owner did :(
Thanks
hum.....ok...
I wonder what the connector in front is for then...its identical to the front o2...
thanks
By rubber grommet...only one i see has a small piece of rubber hose coming off...a drain i assume...I dont see any wires at all under the car :(
The connector is under the carpet on the drivers side. You have to take the door jam/running board off to lift up the carpet. If you search there is a guide for this somewhere.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
