where do these plugs go...what are they
DARKTSI
51
Oct 15, 2007
ELSINORE, California
i just did a swap from a 95 4g63t to a 98....maybe i dont need these but can some one tell me what they are or where they go
the green and orange connectors
close up of the green one
close up of the orange and also ### is that connector in the middle the grey one??
last one coming from behind the block underneath intake manifold i believe
help please.....thanks:dsm:
the one coming from under the intake is the knock sensor and the plug in for that should be on the passanger side of the engine. It's the only thing that can plug into the knock sensor and are you running your ac?
knock sensor huh?...passenger side can u show me a picture or specific location because i dont see a plug for it.......yup i dont have ac i took it off
Crank and cam angle sensors. The one under the mani I would suspect would be the knock sensor.
On the 95, the cam angle sensor was near the sproket as opposed to the later years where it was on the pasanger side at the end of the cam.
which is which?
the ac i dont need right
what about the other 2
where does the knock sensor connector plug in coming off the block
I am trying to find a good pic of the knock sensor and where it connects but there isn't one. pm your email address so I can send a pic from my phone. Crank sensor you need if you are using the 2g cas and if you are there is a plug coming from the cover thats over the timing belt.
on the cam angle sensor....since the connectors are different in the 95 from 98 can i just cut the wires and run them to use the 98 connector and sensor...the wires are the same color
ok heres my dilema now which of the 2 triangle green plugs is the crank sensor.....theres only one spot for it of the cover where does the other one go
ok so ac and o2 sensors are done..and so is the crank angle sensor:)
also that grey plug in my 3rd picture with the hose going to it...what is it ?
