Where do these 2 electrical plugs go?
ChrisNelson
96
Sep 16, 2005
Bemidji, Minnesota
The connector on the bottom of the picture comes off of the knock sensor. But I can not find where it plugs into!
The other (triangle shaped) connector on the right side of the picture is branching off of the fuel rail harness. I don't see any open plugs for that particular plug.
Thanks for any help you may have! :thumb:
The one of the top should go to your A/C and the other one should have a connecter on the firewall for the knock sensor...check around for the other side of it under the intake manifold.
The top pic appears to be the CAM sensor (the ac pigtail is identical but is longer-pigtail is ON ac compressor).Follow the grey pigtail in the top picture back to under the timing cover..to find that connecter. The bottem one is just like stated ^^^ Its your knock sensor. Plugs in on passenger side of head. Follow your Coolant sensor harness back from the thermostate neck. The knock sensor T's out the harness before the main harness bundle (with the speed sensor I belive).
Matthew
