What Are These Plugs?
Sephent
61
Feb 18, 2016
Medford, Oregon
Hey, so the 96 Eclipse GS Spyder i bought got hit in the front by a lifted truck.. i am trying to replace everything and from what iv found, 3 plugs/connectors got torn.. i was wanting to just replace them but am not sure what they are... here are some pictures of the plugs/connectors themselves and a couple pictures of the damage. thank you very much. besides the connectors, i have pretty much bought all the replacement parts besides the dang radiator core support upper tie bar.. which you cant buy.. so im either going to have to wait it out for a wrecking yard to get an eclipse in, or try to straighten it myself..
also, can these connectors just be purchased at a parts store? thank you in advance for your help.
the big black plug with the white plunger piece at the end has the numbers 64260 on the side of it.
i found out that the connector with the blue wires is #16 on the pictures.. i think the master list might be off a little bit regarding numbers but it is either the radiator fan motor connector or ac condenser connector.. thats the only one i found
this is the hood switch. pin1 - blue/black wire, pin 2- black wire
