Resolved What are these plugs on the firewall?
95fwdtsi18psi
803
Jan 6, 2009
West Laffayette, Indiana
I was doing some emission things when I got off work today and found these three plugs just chilling. What are they for and should they be plugged into something, my car has been acting so funny lately so maybe just maybe a chance? A hope!
Solution
Tan - timing ground plug. You remove the cap and ground the pin if you would need to check your timing with a timing light. It was only found on '95's I believe (not sure about '96, but definitely not '97-'99).
Blue - engine speed test connector
Black - fuel pump test connector
I don't know my car can be quite picky. My fuel rail and a in-line amplifier fuse once had beef, and said beef caused me to be stranded on the side of the road until I could get a jump :)
Thanks Brian. I figured out about the blue one, but couldn't find the rest. :thumb:
Problem solved.
