where can i get shock/strut insulators
moonraker
35
May 5, 2004
Naples, Florida
i am changing from coilovers back to the stock suspension and i need to get the shock/strut insulater that goes on top of the spring. i've called around to advanced auto and napa and they dont have it. i called the dealer and they said that the fronts are $18 each and the rears are $65 a piece. does anybody know where i can get all 4 OEM replacement shock insulators for a decent price?
thanks in advance!
thanks in advance!
Rockville Mitsubishi have the fronts for $10.15 each and the rears for $37.37 each after DSM discount and are in stock. Using my son's 1998 GST vin, the part numbers from CAPS are MR103156 (fronts) and MR103157 (rear). The part numbers for your 1995 should be the same but double check with the dealer.
JNZ tuning is another good place to check and can probably get these for you at the same price.
Also, Mitsubishi Graveyard would be a place to check if you don't mind used parts.
Mike
