Wizardyangsta
- 0
- Nov 19, 2022
Sacramento,
California
My 96 Eclipse RS has a problem. After I replaced the ignition coil, fuel filter, idle control valve, spark plugs + wires, fuel injectors, fuel rail, throttle body, thermostat, thermostat temperature sensor, coolant, and the cluster.
My car has a hard time starting up. It turns on and then shuts right off. After many tries it finally turns on for like 2-3mins but it boogles very badly like it's about to shut off then it eventually shuts off. If I try stepping on the gas pedal it just shut off right away.
What seems to be the problem? Since I changed so many things before I try starting it, I don't know where to focus on to track the problem. Also the temperature gauge is dead. Doesn't show no code but before it was showing code p0300 that's why I replaced all those things above.
