Wheel studs too short
sbailey11
Mar 23, 2013
rochester, New York
i drive a 1995 eagle talon TSI AWD and I have 18" enkei rims on it. for some reason the wheels have deeper wells and the studs dont stick though far enough. i need something atleast a 1/4" longer so i can get more than 2.5 turns on my lugnuts.. Could someone link a website i can buy longer than stock wheel studs for an eagle talon?
Thanks!
Found these on ebay not sure how you feel about that place look elgit though [ame="http://compare.ebay.com/like/260896717196?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar"]ARP Extended wheel studs[/ame]
You are using the correct type of lug nut on the wheels, right? Acorn style as opposed to mag?
^ Best Reply, If you are switching from "stock" wheels to an after market wheel new Acorn style nuts have to be used (no washer), the stock DSM wheels use a 2 piece Lugnut washer combo ( mag type). due to the different sizes of mounting holes these can be small (XXR wheels) which would required a "tuner" style nut.
Provide us with Pics, and type of wheel, and lugnuts used. unless you are running spacers there should be no problem with the stock studs.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
