wheel question ?
That's almost the exact same setup I had on my car for a little while:
Mine were 17x8.5 +38 offset. They stuck out a little, so you may have problems rubbing the edge of the fender depending on how low your car is. The inside edge also came pretty close to the front struts. It's going to be a close fit, you should really try them on first if it's possible.
