Spyder Wheel hub assembly - Question of fit
mutant_spider
Sep 28, 2005
WestChester, Pennsylvania
Are the front wheel hub assemblies the same on all 2nd gen Eclipse?
I ask because I see a lot of sites/eBay listing the hubs' fitment with a note of 'Spyder'. I wasn't sure if this was just in their description to reassure Spyder owners that it would fit their vehicle or if it would only fit the spyder. Here is an example of a wheel hub I was looking to buy:
eBay Motors: HUB ASSEMBLY mitsubishi ECLIPSE 95-04 front absorber 03 (item 250341133380 end time Jan-09-09 16:12:17 PST)
Thanks to all for helping.
I wanted another example and found this:
Parts Bin - Auto Parts and Accessories Catalog - Us-nt513157
After seeing all the vehicles it would fit, including the Talon, I'm pretty sure it would fit but a second opinon would put my mind at ease.
Yes and No............
All the spindles will fit, the diff is that some have ABS and some DO NOT
If you do not have ABS it does not matter, they will all work, just remove the sensor(or leave it and clip the wire, some are a pain to get out)
But if you do, make sure you get one with ABS............unless you don't mind looking at your ABS light.
Side note: the 97-99 Avenger & Sebring also carry the same knuckle, but the bearing/hub is diff (they are bolted in) and be weary of 96 Eclipse built before April, that spindle design is diff.
Hope this Helps!!!:thumb:
Excellent. So the only concern would be a light, no real mechanical issues.
I don't think I have ABS... it's a GS (probably doesn't unless it's standard). I ordered the part and will let you know how it pans out.
Thanks for the help.
Yes............the light (which is telling you the ABS is not working on that particular wheel)
Your Welcome..................anytime:dsm:
    • steelcurtaindsm
    • Syclone#334
