What's the proper clutch fluid for an ACT 2600?
dbritt
178
Jun 9, 2003
Clemson, South Carolina
The longer I've had my ACT 2600 clutch, the worse my first gear gets. I doubt it's my transmission (but it might be), but I'd like to try the cheap things first. I'm going to bleed the clutch lines and I want to make sure I'm getting the right fluid so that it doesn't compress too much due to the extra force from the 2600 pressure plate. Which fluid do you recommend for this clutch system?
TIA :talon:
Cirus_93TSI said:
buy a clutch fork from taboo, it wont break.
Do not do this. Taboo will take your money and not send it. Your better off finding another stock one if you did bend it. I have one if you wanna PM me...but i have had some problem with the 2600 and ended up making a custom adjustable clutch rod..I would also consider that the bushing in your pedels might have worn out...Also might want to make sure the adjustment on the master is maxed out...I dunno it sounds like it could be a fork tho, but if you dont have the time to drop the trans and check i would try some other things. taboos site has a bunch of solutions to clutch problems, just dont buy shit from them.
