What's the easiest way?
SourPlugz69
May 4, 2025
La Grande, Oregon
I have a 1992 eagle talon, my harmonic balancer is broken and I'm trying to remove it off the motor to replace it, I've been doing research everywhere and I can't find anything on if I need to remove the engine to remove it or if I'm able to just remove it through the wheel well? Any tips will be very appreciated
If it's a 4G63, it just involves removing the 4 bolts that hold it to the crank sprocket, sometimes a few taps with a hammer to loosen it off the center bolt(which doesn't need to come out).
On a 2g it's a very tight fit but it fits between the frame and the crank sprocket. I'd assume a 1g is similar.
