Whats the diffrent between DSM and EVO injectors?
kristmen
572
3
Oct 26, 2002
Southwestern, Michigan
Like the topid says.
Whats the diffrence? For example, this is from FIC's home page.
EVO 650 cc. Peak & Hold EVO125-650 Set/4 SPECIAL $300
MITSUBISHI 650 cc. Peak & Hold #125-650 Set/4 $310
I know its only $10 bucks but um those are the same injector technicly right? Doesnt an EVO use the same type/style injector as a DSM, only slightly larger stock wise?
Unless you typed it in wrong, the part number is the same. I have put EVO8 injectors in my car with no extra parts so there should not be a difference. Maybe they charge 10 more dollars for the EXACT O-ring for the DSM but it is not necessary if you have a set of injectors already with good condition rings on it.
Hell the lower seals they include with the DSM ones are crap so that doesnt matter.
Everyones been switching to OEM's.
Anyway ok thanks.
