What year motor do I have
MU_TIGERS
Dec 17, 2002
Boonville, Missouri
I have a question, and hopefully one of you guys can help me. How can I find out what year engine I have in my car. I bought a 91 GST, but it had another moter put in it. I'm wanting to know how can I find out what year it is. I know it's a six bolt, but other than that I have no Idea.
Yes, the letters on the valve cover are red. Are they different between the 90 and 91's
look at your throttle body, if it has 4 vacum ports on the top it is 91-94 if it has 2 it is a 90. You can also pull the ECU and check the serial code with the vfaq serial code list.
Okay, I was able to get the Engine Identification number, if possible could someone translate it for me. Ok this is the top line, (Some of these might be wrong b/c it was dark and dirty,boobQ(maybe o)L, the second line is GV4133. I'm thinking it's a '90 motor.
The motor looks like it has all the sensors in it, but I don't know if they're from the this motor, or the '91 motor. If they're from the '91 motor will I have to switch them out? Do I need a '90 ecu, or will the '91 work? Will I have any problem with the tach not working? I'm sorry for all the questions, but I'm new at this, and I would rather fix this car than buy one that is already working,which I had the oppourtunity to do, so I would appreciate any information.
