2G What would I need to do for a fog light conversation on my 1997 Mitsubishi Eclipse RS !
Gunther2grs
Nov 28, 2021
Elkgrove, California
My 97 rs never came with fog lights. What would I need to do to install these and make them work.
you need the switch, relay, foglights with brackets and the bezels. You can probably cut you stock bezels to work if you'd rather do that.
i know the 98-99 cars have the plug for the switch but i'm not sure about other years, so you should check to make sure you have it on your harness. same with the connectors for the foglights.
If you have them, you just need to bolt up the foglights and brackets, install the switch, plug everything in and install the relay.
