What valves will work
Projectpat115
39
Jun 9, 2004
Waterford, Wisconsin
I have a 97 gst and most of the valves are bent. what valves will fit the 2g 4g63t? do i need to find 2g valves or wil 1g work? the head needs machining so if machining needs to be done to make 1g fit thats not a problem
The sizes for the valves are the same on all years, intake and exhausts are different from each other. If your going for the cheap replacements I've seen "oem style" at machv and slowboy. Stainless you can find at any DSM vendor around 230-250 for full set.
Your probably going to need new valve guides. If you have a reputable shop check out the head they will be able to tell you. If you don't want to waste time doing the job twice have a shop cut the seats and valves to match for a good seal and replace the stem seals.
