what to look for on a used fidanza flywheel?
daarkness92
85
May 1, 2007
Rochester, Michigan
I need a new flywheel to go with my act2600 set up, and theres a guy right by my house that is selling one. he doesnt know how many miles are on it but it looks very good, my question is what should i look for to determin whether it is good to buy or not? Heres some pics of it....
yes its for a 6 bolt awd but are there any common defaults in these flywheels that i should look for?
Check all the ring gear teeth, look for any broken studs, missing/broken dowel pins and stripped threads.
Make sure it is for an AWD. Also check if your 92 is a 6 bolt (early 92) or a 7 bolt (late 92) and make sure that you have the correct flywheel.
I'd order a new surface for it, if I were you.
well I ended up buying it because it looks really good and has almost no flaws, it has definitley been used though. I'm going to take it up to a machine shop and have them look at it and measure the step for me...thanks for the help guys
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
