what to do about rear brake caliper dirt shield rubbing against rotor
juntjoo
780
Sep 12, 2011
fort myers, Florida
when I tighten the top caliper bolt there is no gap between caliper and the rotor and when I then removed caliper to inspect the situation I noticed the dirt shield pushed against the rotor towards the axle seizing the rotor, then I repositioned it off the rotor and it spun freely. anyone had this problem before? any suggestions?
is the dirt shield supposed to be fixed -off the rotor?
Its supposed to be bolted to the hub with the caliper bracket. once its secure bend it back enough so it doesnt rub.
yeah, I ended up having to sand rust off a lot of surfaces to the wheel to spin. prob solved.
