What to do about Exhaust?
X|Crescens
251
Dec 2, 2002
White Bear Lake, Minnesota
I've been looking around for an exhaust for some time now. I recently bought full 3" downpipe and am in desprate need for an exhaust. I wanted a stock looking exhaust, no can. I've been searching the forums and I've found that the Bosal exhaust system is a full 3" and comes with dual tips, looking like our current stock exhaust. I found a write up on the bosal exhaust http://www.dsmtuners.com/forums/showthread.php?t=94023 that he had purchased his bosal system from www.seffects.com in which I went to this site to order it but they are on "Special Request" only. So I e-mailed them about getting the exhaust and they replied "I’m afraid they are on factory back order with no ETA on when they will be in stock again." So I've been searching this forum and the internet to order this exhaust elsewhere with NO LUCK! Does anyone know where I can order this exhaust from and if not anyone have any ideas for another exhaust? Dual tips not neccessary but i didn't want the huge can look. Thanks in advance.
I know that Magnaflow makes mufflers with dual outlets. Can you have someone make the exhaust for you, then have them put on whatever muffler you buy? I would also look into buying the parts from Slowboy, if you want to. Since they normally use Magnaflow mufflers, then you should have no problems getting the one you one and attaching it to these pipes.
http://www.slowboyracing.com/shop.php?sid=PHPSESSID=da8bd445edac117d9b0c4dca24bee8b5&cat=139
Good luck!
Adam
Sorry to revive an old topic: I would like a Bosal exhaust system, however have a GST. I read somewhere that the NT system will bolt onto the FWD turbo cars. Is this correct? Has anyone done this?
Thanks in advance :)
If your looking for a stock-looking exhaust system, you may be interested in the RS*R Exhaust Magic (ExMag) system. It has 70mm (2.75") piping, and sounds awesome...If I didn't have such a good hookup @ a muffler shop, I'd purhcase one. You can check it out @:
http://www.prostreetonline.com/buy/rsr_exmag_catbacks/
(They have a 2WD model listed...I spoke with a rep at a local shop and they said they do offer a system for the AWD model as well...but I'm not 100% certain, you may want to check it out).
It isn't dual tipped like stock :| Going to sound much different/louder. Basically I just want the stock system, but better performance...
