What the heck code is this?
Slammed0
185
Nov 26, 2004
Boise, Idaho
I got this code. P1294
Injector High Side Open - Bank 2/Target Idle Not Reached
Well lesson learned for me. I thought all computer codes were always directly related to a sensor. So that you knew what sensor or equipment was failing. I guess not. This is just basically telling me my car isn't running/idling right. Which is obvious to me cause of the erratic idle.
So...any suggestions on where to look? I searched this site and didn't find very useful information that could point me in a direction. Also, where the heck is bank 2?
Thanks guys!! :dsm:
i believe that bank 2 is the 2nd o2 sensor but I'm not sure, seeing as how i don't deal with much obd2 stuff. sounds like you should adjust your biss screw and check to see if you isc is functioning properly.
Ya that very well could be. I will check that out and see if I even have 2 O2 sensors.
