SasaniFab
- 2,432
- 788
- Dec 1, 2013
Mexico,
Connecticut
I was looking at my logs and I did some reading and got varying information. In my logs im seeing anywere from 203-206 degrees just driving around. When I do a hard pull the temp will go as high as 212. There are times when im in high boost the temp gauge will creep past half way and quickly fall back below half way. I have a mishimoto aluminum radiator for cooling and a new waterpump. My coolant is clear and has no signs of contamination. Have any of you guys experienced this. Im pushing the stock headbolts to 22-23 psi on a fp green.I was worried I might be pushing coolant or lifting the head. Ive heard that the 6 bolts head studs are very strong in comparison to 7 bolt. I am also running 50/50 meth injection with conservative timing so my Iats are cool.
