what size injectors with big 16g?
Gst18
147
Oct 3, 2005
Madison Heights, Michigan
I was just wondering what else i would need to get my car correctly tuned.
Mod list.
Ported EVO III Big 16g
Ported Mani
Ported O2 Dump
3 inch dp
24 x 12 x 3 intercooler
2 3/4 inch IC pipes
gm maf and translator (blow through setup)
rebuilt head, 1mm oversized valves
MBC set at 15psi
Running stock fuel
I would like to run it at 20 psi. Just wondering what i would need to run it safely at 20-21 psi
and around how much power can i be expecting to make out of it?
550's are enough for that boost level and I used to run mine to 26 on stock cams. If you plan on running high boost with aftermarket cams, get 650's and a 255 HP pump with an AFPR.
We don't know how much power you'll make from your setup since so much is dependent on the quality of the tune. Don't forget that larger injectors will require either an EPROM ECU/Keydiver Chip, AFC or DSM Link for proper control. Dyno it to find out for sure. Asking is considered bench racing and against our site rules.
Good luck with your build,
Andy
well wouldnt i be able to use the translator to set the injector size?
