ECUflash What settings are the high hp guys using?
ed1380
Supporting VIP
2,973
54
Sep 29, 2007
ATL, Georgia
I'm having an issue with the engine load going to 0 when it hits 300. I have ceddymods big maps which goes up to 340, but something is limiting it to 300. There's people making more power than me, so obviously I'm doing something wrong and I can't find anyone with the same problem. Here's a couple load logs to show what I mean.
What is your load limit set to? I haven't messed much with the DSM black box but normally the load limit on the stock evo ecu is 319 and you can raise it or switch to a different load limit. Does the car cut when it hits that area? The log looks weird as the curve continues the normal path after the drop.
