precision 1000cc injectors?? what are your settings
myblack98gst
578
Jun 22, 2003
Elizabethtown, Kentucky
I have burned 3 chips for these things and cannot get the tune right it starts and idles perfect when it is cold and full throttle is good but warm idle it tries to die or just dies and cruising it is showing lean 16.0 if I blip the throttle it will come back into the correct range then lean back out at low throttle same with idle...
the current chip is for 950cc compensation and 432ms deadtime at 14volts
what are you guys using for these injectors..
p.s. I am using tunerpro
