Staged
- 76
- 0
- Apr 16, 2003
Beaumont,
Okay, feedback for all the future questions:
Balance shaft belt went nuts, and the oil filter literally spun off during a run in with a Mustang SVT (Which I spanked anyway).
IMMEDIATELY shut down when the AutoMeter warning came on and pulled over. Put a new oil filter and oil on at site and started it up. Belt was squeeling like crazy. Embaressingly, the Mustang took me for the oil and filter.
You think this is a remove the balance shafts question? It's not.
I cut the belt off and took the car home, still plenty of power. Next day, replaced the balance shaft belt, and checked the shaft play and it turned decent enough. Started the car and SMOKE EVERYWHERE! Lots of squeeling and I shut down. Balance shaft bearing is froze. Screw it, cut the $16 belt off and left it, we could all use a little vibration for the ladies...
Changed my transmission, went Stage 2 clutch kit, replaced timing belt and belt adjuster, replaced even the valve cover bolts. Serious tapping in the valve cover!
Replaced the valve lashes with 2nd gen and then tried again. No inside warning lights, oil pressure is there, lashes are quiet as a sleeping baby, no leaks, timed correctly, tranny is solid for a launch.... and ........
Boost went from 16 to 4 or 5 !!!!!!!!!!!!!!! Bishilvr mentioned the knock sensor, but I am out of state, and I forgot my cable, so I have no idea if that is skyrocketing! I am going Baton Rouge next weekend and we will datalog it there on a friends line. It drives like a 92 Automatic 1.8lt and I don't know where to go with this!
I am stuck in Texas! Well, it drives, and all... but I can't make this road trip unless I am racing... Shoot, I am thinking of racing a few 4cylinder automatic Mustangs to keep my moral up a little...
Any other ideas or a fix for temp to get me to my friend in Baton Rouge? My Dad is tired of me using his garage! Help me to help him!
