what pistons should i run
Arcangel2501
47
Jul 26, 2012
Okc, Oklahoma
hello i need some info i got some manley turbo tuff i beam 156mm rods from a friend out of his evo8 and im putting them in a 4g63 7bolt 99 eclipse gsx short block with a 88mm stock crank im going to run wisco hd e85 pistons but what should be the size of the pistons
You need to run the "stroker" pistons because of the longer rods(stock is 150mm). The wristpin is moved up higher in the piston to offset the size of the longer rods otherwise they pop out higher than your block. As far as size I dont seem to understand what you mean the size depends on the condition of your block, if its virgin with good walls take it to a machine shop have it clean and deglazed to see if you can run standard size pistons. In the case your block has scratches in the cylinder walls you might need to bore it out, again depending how deep the scratches are. Just remember if is in too bad of shape where you have to bore it out more than 60 over you might want to look for another block hope this helps.
