What other cars had a 7 bolt crank
ed1380
Supporting VIP
2,973
53
Sep 29, 2007
ATL, Georgia
Have a spun rod bearing on a 97 gsx. auto so I'm not worried about crankwalk.
So far I know 93-99 4g63 have a 7 bolt crank that'll work.
I've heard that some gallants and hyundais have a 4g63. Also there are the na 4g63's, but I don't know which of them will actually interchange.
Im willing to go with a 100mm crank and pistons if it turns out cheaper that way.
Its for my fiance so nothing crazy hp-wise. maybe 250-300
Thanks
I might have one for sale.... I need to inspect it for wear but Im sure its good to go. I will get back to you as soon as possible
1992.5 also have the crank. I own one ;).
i've have seen the 4g63 in old school hyundai sonatas.
I'm pretty sure all the cranks are compatible.
I have heard of a issue on the non-turbo's having a small line up tab that you have to grind off in order to use turbo clutch/flywheel related components.
If I'm wrong please let me know. I know that around 97 they changed thrust bearings design.
