What OFH do I have?
sypherzero
461
7
Feb 14, 2008
Marion, North Carolina
Hey guys, I got an extra OFH when I bought a block for my car. So can anyone tell me what year/model this if from? Thanks!
Yep, that's a 1990 6 bolt ofh. They are better IMO, because, when your bearings go, and you throw a rod, you can just throw away the external oil cooler and buy a new one for cheap. If you have ever priced a water cooled ofh, you will see what I mean....don't try to clean a stock oil cooler, won't work.
Looks like a 7-bolt housing to me, in which case it'd be from an Evo III. The bolt spacing of the bottom two bolts seems a bit too close for a 6-bolt and the casting shapes within the mounting surface do not match a 6-bolt.
You are correct, after comparing the spacing to a 90 filter housing i have it is definitely from a 7 bolt.
