What kind of turbo
goldeninja20
589
3
Dec 5, 2010
Norton, Massachusetts
I just bought a gst. The car came with a 3 inch downpipe. The downpipe is a vband set up. Is there a turbo that is around the size of a 16g that i can run with a vband set up. Is there a way to make a vband set up out of a 16g? Should i sell the downpipe and get a turbo and make another? (Also the manifold is a tubeular and not the stock log) Any input would be amazing.
Ok great. Ill have them up in 5 min. Ill go take them now
What do you guys think? The manifold isn't bolted on all the way. Almost all the way.
What do you guys think? The manifold isn't bolted on all the way. Almost all the way.[/QUOTE
Does your mani have a factory flange? If so, I would get rid of the vband set up and get a downpipe to match a factory style turbo.
I've never seen a 16g with a vband o2. I would just remove the vband piece from the DP as it looks like it is just bolted to the DP, and install a 16g with a stock o2 housing.
Looks like someone was in a hurry to get that turbo off, that return line they snipped was a nice one..
IIRC, some of the FP Turbos are available with a DSM flange and a V-Band outlet. However it looks like you can pull that O2 adapter off and run a standard in its place.
should i make my own downpipe with the 16g. Or is there something that will bolt up there. And yes he was in a hurry to get it off LOL. I bought the car, he wanted to take his turbo off, so i said take it off and when you have it off ill give you the money. So he probably was in a hurry.
As stated, there is a flange on the actual down pipe that will likely bolt to the stock style o2 housing. You will never know until you get a turbo and o2 housing bolted on there. I would take that header and throw it in the trash.
