What is your opinion on this turbo?
Honda hunter 1
83
Nov 4, 2009
magog, Vermont
I just blew my turbo(turbonectic t3) and I would like to purchase a pte 6131.I don,t have a big budget that,s why I would like to go with this turbo,is this a good turbo for the price 599$ or should i get a secondhand turbo like a turbonetic or a 20g to replace my old turbo?If I go with a 20 g I have to replace my manifold, downpipe ,so to me the best option would be to get another t3 turbo that would bolt up to my 5 bolt downpipe.There is a link to the turbo I would like to purchasehttp://www.precisionturbo.net/turbochargers/entry-level-turbochargers/details/Entry-Level-Turbocharger---6031E/61
The 6152 is unreliable and has too small of turbine as it is....mating a GT35R compressor to a T31 turbine wheel that is not much larger than a TD05H is the most ridiculous thing I've ever heard. I'd get as far away from that idea as possible.
The 6031E is a little better-matched airflow wise but you'll need about a .82 a/r turbine housing if you want to get enough flow out of that T31 turbine.
So what turbo do you suggest for my budget?I,m aiming for the 500 hp,my setup is stock motor with a ported head, 1mm oversized valve, dual springs,hks 272 cams,and all the supprting modes,my budget is from 500 to 600$,should I go with a used turbo or a new pte?
can a 20g come with a t3 hot side?
