@TDC
- 455
- 13
- Sep 10, 2012
Nor-Cal,
California
Hey guys. I've been boost leak testing and I basically got all of my leaks fixed but I'm still not holding pressure. I am leaking out of my vacuum line that comes off of my valve cover and goes into my intake pipe. I also am leaking out of my PCV valve. I took it the line off if the PCV that goes to the intake mani and plugged the nipple on the intake mani. I had boost leaking out of the PCV. So basically I have boost leaking into the crankcase. This could either the rings or valve seals correct? I tried closing the intake valves by setting it the motor to 40* BTDC but I couldn't find the part where there all closed. There was always one cylinder that had the intake valves open when I would test. I rotated the crank at least 15-20 times trying to find this point. Is I am only needing a tune to have my car finished performance wise. Is it even worth going through with the tune at this point? Here is a video of my test. You can see and hear the leaks coming from the vac line and PCV valve. Also keep in mind that my gauge on my tester is zeroed at the 9psi mark. This text was done from the throttle body elbow with 20psi. Any help is appreciated.
http://youtu.be/rRaIl2QkK_E
