what is the size of the lower control arm bolt?
95_Talon20
Sep 6, 2014
Kansas City, Missouri
Replacing my wheel bearing and that is the last thing that I need to take apart. To take out the cv axle and get to the bearing bolts.
Just take the old bolt with you to ace hardware and match it up with a new one. Or you can order a new one from jnz! If your asking what size the bolt head is, it's 17mm I believe!
Both thru bolts are 17mm both sides, the ball joint nut, I believe I used a 7/8 wrench. Then a bfh to break the joint:beatentodeath:
17mm it is. Please be careful using Ace Hardware bolts, I have had 2 break that I put in the steering knuckle to strut mount, outcome was not good. I use Dorman bolts from my local Thirlby Automotive on all repairs now!
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
