What Is The Best T28 On The Market Today
Why t28? What are your goals for the car and what other parts will you be installing? Big t28s should be capable of around 300whp with the right mods
A little searching on this website will give you the answers you need...
http://www.dsmtuners.com/forums/bolt-tech/202801-fp-big-t28-vs-t28-killer.html
Oh and by the way...welcome to DSMtuners! The moderators are pretty strict on the rules, so make sure to search before posting a topic to see if it's already covered. Most of the time you will find that your questions have been asked before. Also check out VFAQ Site - Visual Frequently Answered Questions
The cops in your town can visually tell the difference between your stock turbo and something similar like a 16g? 16g's are cheaper, but requires modification for install along with extra parts. If you want a turbo that looks as stock as possible than a big T28 should do the job. If you go with a 16g choose the evoIII 16g since it has the best potential out of the 16g variants and would cost about the same as the big t28 when you add in the install kit needed for the 16g with probably a port job too.
T-25 on the left, FP Big T-28/28 on the right
T-25 on the left, 16-G on the right
