what intake pipe and what size inlet to get for my small 16g turbo?
3134
236
Mar 7, 2004
Bronx, New York
I have a small 16g turbo and was was looking at two different intake pipes. One was the dejon 2g 2.25 intake pipe which is priced for $35.00. The other is the 2g dejon curved intake pipe that starts at $125.00. I heard that the 125.00 intake pipe does not fit without getting some things so what do I need to make this pipe fit? Also, does the first pipe fit and is this a good pipe to get or is the more expensive pipe worth the money? Please, this is such an easy thing to get, but I have heard a million things about what I need and stuff so can someone just let me know which pipe is better and also everything I need to get with the more expensive pipe (sizes of inlets, hoses, etc.) thanks :)
this is the site I got the prices from: http://www.turbogarage.com/dsm_intake.asp
The $35 one...
2-1/4" Elbow for stock Intake pipe
installed on stock MAS Pipe Black Only
1. Increase Intake area 45% over stock. Reduces intake pressure drop and restriction from the internal BOV tube.
2. Made from 2 1/4" OD mandrel bent tubing.
3. Requires cutting your stock Intake pipe. Rubber coupling and two clamps are included.
4. Mounts MAS in stock location and orientation CIP-2gB Shown Assembled to Cut Stock Intake Tube.
CIP-2gB - $34.95
If you still plan to use the 2G MAF and not the GM MAF/MAFT, you can get this one.. which is second one down on their list of intakes.
Go directly to their website to get more info. www.dejonpowerhouse.com
The ebay piece is nice, I have one with K&N filter. Fitment is good, it hooks up to all the emission hoses and you can use the stock bov return tube.
The couplers included are 1 ply, they work fine though. You may have to purchase some bolts for the MAF adapter, I did, although you may be able to salvage the ones from the stock airbox (I didn't try). I sprayed painted my pipe black because the chrome was too blingy for me.
You might have to get a reducer/expander coupler though depending on how big the inlet on a 16g is.
see i sorta want to buy something where it will just bolt right on w/o having to get reducers and everything because by the time I get this it will be right before the shootout in etown and I definitely want this on before then. If anyone can let me know how this ebay piece will fit with a small 16g turbo that would be very helpful.
