3" intake pipe to 4" Turbo inlet
We're on Boost
3,047
1,468
Aug 25, 2007
Seattle area, Washington
T9S1i asks this question in the Turbo system tech forum:
Do the bolt-on s256 from bullseye come with a 3" inlet or 4" inlet on the compressor cover? I could have sworn i've seen pictures of both...? Just trying to figure out funds here and if im going to have to get a bigger intake pipe or not.
Danny you don't necessarily have to use a 4" intake pipe just because your compressor inlet is 4". Take a look around on the other forums like evolutionm.net and srtforums. You'll find pics that look like this one on evom:
AMS 3076R Kit Evo IX Dyno Results. - evolutionm.net
This guy JohnEB took some great pictures of his AMS turbo kit. The pic you want - scroll about 1/3 of the way down the page, it's the picture just below the one that says "Cosworth Power to Pass". It shows the intake pipe and turbo assembled. This is a GT3076 (4" inlet) and you can clearly see that the intake pipe is a bunch smaller, probably 3", and it connects to the compressor inlet with a 3" to 4" silicone reducer hose.
There is a reason why this is ok. Turbos like the GT3076 and the Borg Warner S256 have a 4" inlet because the outer part of the inlet is taken up by the anti-surge ports. The actual compressor inlet is only about 3" in diameter, or even less. The anti-surge ports don't have to have air blasting at them from the intake pipe. In fact, when the anti-surge ports are doing their thing, they are actually letting air OUT of the compressor (flowing backwards). Here is a good diagram with words to explain what this is for:
TurboByGarrett.com - Turbo Tech103
Scroll again about 1/3 of the way down the page to Fig 2. Their words actually don't explain it very well but the diagram is good. The explanation is that surge happens when the airflow over the inducer blades becomes disrupted and turbulent. This is aerodynamic "stall" just like when your airplane stalls because you are going too slow. When that happens in an airplane you get a lot of buffeting. The buffeting in the compressor inducer is called "surge". If you can speed up the airflow through the inducer you can prevent buffeting. The compressor WANTs to pull more air in, it just can't because it's got nowhere to put it when your engine is sleeping at 3000 rpm or whatever (whenever your running conditions put you to the left of the surgeline on the compressor map). But with the anti-surge ports there it's got someplace to put it, it just blows some air back out through the ports. Or something like that. Maybe an aerodynamicist specializing in leading edge slat design would have a slightly different take on this, hey?
So there you have it. By the way, the reason you aren't likely to find fancy setups like this on DSMs is because the big-name tuners don't make these high-buck kits for our old cars. :cry: But you'll find this stuff on the late model cars like evos and SRT-4's.
Gary
Good post Gary!
Gary
You do know that an aircraft can stall at any airspeed and at any attitude - right? ;)
Gary
Automoto Sports Copyright&copy AMS 2006
Granted, it's a 35R instead of a 30R, but otherwise it looks to be the exact same kit, for a DSM.
Yeah, I know about this kit. In fact I even called AMS and talked to them about it several months ago.
Here's the thing about it: Notice it doesn't include the fancy tubular manifold that you can get with the evo kits. They do say at the bottom "we offer a stainless steel tubular header to be a bolt-on upgrade for the this kit" but I've never seen one or heard of anybody that has one. If you have a few dull moments one day, call them up and ask them to send you a picture of it. LOL I bet they don't even have a picture. What really turned me off was when I asked, can't remember his name, but the guy I got on the phone, about clearance between the O2 housing/wastegate to the oil filter he said "Oh they don't even come close". I know that's not right and I tried to explain to him my car is a 1990 with the sideways air-cooled oil filter that comes very close to the O2 housing, but he didn't get it. I know the exhaust manifold has to be designed from the ground up with that clearance in mind, because the manifold determines the position of the turbo. I decided if I go this route I will probably buy the manifold from Shearer Fab and I will talk to Ron Shearer on the phone about it and ask him to make the O2 housing as well - everything to fit the 1990 DSM. I know he will do it right - but there you go it's a custom job. I've asked AMS for custom work before and they said, "Sorry, we don't have time". A local shop here (Speedware) told me AMS is very busy with "manufacturing" these days. Yeah. Manufacturing stuff for EVOS.
On the AMS kit, they make it to use the 5-bolt (ford style) turbine housing only, with the wastegate on the O2. And they make an open dump only for the waste gate. I didn't want any of that. I wanted a 4-bolt T31 turbine outlet (2.5" dia) with the wastegate on the manifold, and a wastegate dump that dives back into the O2 housing (or the downpipe) right exactly where the diameter steps up from 2.5 to 3 inches. There would have to be a flex section or a slip section in my dump tube.
Anyway what I'm trying to say is, with an Evo, you can get all kinds of choices and find pretty much what you want already designed and available in a kit. With a DSM, not much available for full-up kits!
Gary
Hey while I'm complaining on this subject (the above) let me throw out one more from my pile of accumulated complaints.
The Evo Green turbo. Great little turbo. But it's reverse rotation and all, not really very adaptable to a DSM. So I asked FP if they have any plans to make a version of this turbo that's turned around to fit DSMs. Nope. I asked AMS if they had anything for DSMs that would perform like an Evo Green. Nope. They did say a TDO5 20g would be pretty close but no cigar. Asked Extreme Motorsports the same question. Nope. Buscher Racing, nope.
The Evo Green is kinda unique because of the light weight wheels that are machined from billets (both the hot and cold wheels). I would think FP could take their NC datasets, mirror them or whatever, and with about 1 day's work they could be milling out normal rotation Green wheels for a DSM version of the Evo Green. I don't know about the housings and bearings, they could probably use existing stuff for all of that. I just don't think it would be that hard.
But it'll never happen..:beatentodeath:
Better for me! I wont have to buy a 4" pipe now :sneaky: since the 3" performs about the same.
Yup, that's what I meant. I don't know that it is actually better. I am just thinking that it must work pretty good otherwise these high-end tuner/builders wouldn't be making them that way.
Gary
Good post Gary!
Dee how the heck are ya. Flying right? You aren't the one that crashed that B2 are you?...:p
Hey what do you think. About how anti-surge ports work I mean. Do you think it's all about speeding up the air flow through the inducer, or do you think it is an aerodynamic trick that reduces the stall speed of the inducer, or what? Reducing stall speed - isn't that what leading edge slats do?
Gary
Yeah I don't understand some of these big name companies that don't sell more parts for Dsm's. Evo's are sick cars but I'd be willing to bet there are way more dsm tuners than evo tuners. Some of these companies are missing out on ton of money by not making more parts available to the Dsm world.
Totally. Woohoo, I'll throw another one on the pile:
My exhaust system, HKS High Power. Was designed probably 12 to 15 years ago (just guessing). HKS big tuner name. This is a 65mm system (basically 2.5 inches). It sounds great but really it is too small if you are going to upgrade your turbo. HKS doesn't even make a proper 3" system for the 1g. They have never bothered to redesign/upgrade this system all these years.
Apexi, not much better. Their 1g exhaust is mostly 70mm , still not 3". And their piping isn't stainless only the muffler is. Again it is a system that was designed a long time ago and has never been updated.
There is some better stuff available for the 2g. But most of the really cool stuff is made for the Evo.
Gary
Gary
Yeah hks doesn't even make a FMIC for DSM, ridiculous!
We just got lucky:
Forced Performance: DSM 20G-6SL2 Street/Strip Turbo
It's not a DSM version of the Evo Green like I wanted, but this is pretty darned cool. TD06SL2-20g for DSM. Tired of paying Greddy $3000 for their version of this turbo? No problem, next time buy it from good old FP - $999! ;)
This was just added to their site in the last couple days. It's beeuutiful, take a look!
Gary
