What size is the turbo inlet for a 16g?
Its been awhile, but I'm pretty sure its right around the 2.25" range (probably actually metric, but close enough). If you can't find a proper reducer, just find some 2.25" ID rubber or silicone hose, cut off about a 1" section & use that as a reducer/spacer.
I've attempted to squeeze a 2" coupler on there, without success..
2.25" fits well.
Also the ring that fits in the stock 2G intake can be used. It's a tight fit but is otherwise sized appropriately.
