What injector settings with gm maf
eclipsetuner_21
106
Sep 16, 2006
Liberty, Missouri
I am running a gm maf with Delphi 780cc injectors. I want to know if I should set the translator for 780cc or because DSMLINK Wiki says my actual flow of the injectors is 749cc, should I set it for 749cc?
Do you have dsmlink? If so, set the maft for stock injectors and use dsmlink's global and deadtime settings for the injector compensation. If you don't have dsmlink then set it for 780's.
