What holset do I have
choice
Apr 16, 2014
wenatchee, Washington
I bought this 97 gsx 6 bolt swap with a holset. Turbo seals are bad was going to replace with another holset and rebuild my current one. How do I tell what holset Is in my car and will any holset bolt in place of current one?
I think the tag has been removed I'll get some pics of it tomorrow. I was told it's a 72mm. Also I was under the car and found I have a Megan 3" downpipe with a Megan 02 housing but the 02 housing is only 2.5" and some retard put the two together using just 1 bolt to hold it together what can I do to fix that? Should I take it to an exhaust shop and have them weld a new flange so they match.
Add a second bolt. The holes in the flange are slotted so they will line up. And it's fairly normal for people to use a 2.5 o2 housing witha 3" dp.
If it's a 72mm inducer, then it's a hx55. However that specific turbo is huge, and is hard to mount without a custom manifold. What size housing is it in.
Really need a picture to be able to tell what you have.
