What hardware is necessary for exhauust manifold ?
98EclipseTurbo
122
Mar 22, 2004
Northwest, New Jersey
I am bolting on my exhaust manifold and I dont see any other hardware beside the nuts. I know that stud kits for exhaust manifolds do come with regular washers and locking washers. Should I have them installed since and is my exhaust supposed to have them from oem ?
Washer are there to space the bolt so you don't run it in to far. If it had washers on it to start with I would put them back on. The studs come with nuts and lock washers because the lock washer is use to keep the nut from backing off. I don't recall lock washers being on there stock. You should need lock washers unless using nuts or having trouble keeping the bolts in. Hope that helps.
I am not sure it there is supposed to be any washers installed since the nuts have a build in flange with grooves on the back to keep them from loosening, or at least that what is seems like. should I add on the locking washers on to that type of a wahser and are the oem nuts with flange used for locking them in?
Perhaps the aftermarket stud kit comes with with additional hardware since the nuts are not flanged like a washer and do not lock ? Long story short I have to change the head in the spring and untill then I need to fix my exhaust leak at the manifold because of a broken stud, so I know there is nothing wrong with the turbo and have the best seal possible untill then.
Thank you
www.ssstuds.com is one of our site sponsors and they sell stainless hardware kits for our cars.
Here is what is required to mount the exhaust manifold to the head on a 2g:
- Seven (7) M8 Studs
- Seven (7) M8 Locknuts
- Seven (7) M8 Flat Washers
- Two (2) M10 Studs
- Two (2) M10 Locknuts
- Two(2) M10 Flat Washers
Or if you are not using locknuts then you would need lock washers too.
Hope this helps!
