What fuel pump will work for e-85?
Eagle Talon 671
6
Jun 27, 2013
Las Vegas, Nevada
i need help on figuring out what fuel pump will work i am planning on running on e-85 with 1200cc injectors and i have ecmlink v3 to tune with i just need to know what fuel pump will work for e-85?
If you want e85 compatible , you can start with Walbro 450.. keep in mind you will need more fuel and possibly a bigger fuel pump depending on your horsepower goal
Walbro does not certify any of their fuel pumps for E-85 except for the Walbro 450. Just keep that in mind if you were looking for something smaller than that. I know people get away with using the 255LPH model for instance, but it's not recommended. I'd also give Deatschwerks the thumbs up because they use a turbine impeller design which is much quieter than a comparable Walbro. That in my book is worth the little bit of extra cash.
Ive used the aem 320 green version. No problems with it submerged in e85 past 2 years. If I had more than an e3-16 I doubt it would keep up though and a dual setup with a hobbs would be needed. Check your goals, check your fuel requirements, ensure compatibility.
+2 walbro 450. You could go with any number of pumps but it IS rated for e85 and itll give you some headroom, power wise. Cheap/easy install(at least on a fwd it was easy)
Walbo 450+3. Also I have had luck with holley pumps, just if you order one double check e85 compatibility... Most are...and mine is, but just be sure.....great bang for the buck those holleys
