E-85
Dusty96
Nov 15, 2016
New Windsor, New York
If I bought a car with a Shitty E-85 tune. What is needed to go back to 93 octane? Other than a tune/adjusting fuel to air ratio.
That should be all you have to do. The setup for e85 also works for 93. I.e. Fuel pump, injectors, lines etc. I run a flex setup on mine and the only difference is the tune and GM sensor to read the ethanol content.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
