boostmaniac
- 54
- 0
- May 19, 2005
Us of A,
Georgia
I am just wondering having 550 AWHP what will hold up the longest and what is gonna go first?
boostmaniac said:I am just wondering having 550 AWHP what will hold up the longest and what is gonna go first?
at 550 AWHP you will have problems with pretty much every stock drivetrain component on a 1991 DSM. here is a list of what to upgrade before you put that 550 AWHP to the ground ; change the 3 bolt rear to a 4 bolt rear, put a good pressure plate and disc in there (ACT 2600/2900 or comprable), the stock flywheel will hold that amount of power though for quicker revs a lightened flywheel would be nice...but not neccisarily stronger, most of them have actually been proven to be weaker than a stock flywheel or more suseptible to damage or wear. next will be parts of your tranny starting with the center diff...i would suggest a full race build by Shepard Racing. you may want to consider upgraded CV axles, though i would suspect that the OEM ones can take quite a beating, the transfer case should be fine, and the driveshaft should be ok also. im putting down nearly 400 AWHP to the ground and that was a trick enough.boostmaniac said:I am just wondering having 550 AWHP what will hold up the longest and what is gonna go first?
liquordrunk said:well he is on here. DSMTRANCE. his axles snapped at the track. he was fwd w/550 whp.
