What does it mean to 'kiss' a rod?
RoasT BeeF
2,139
22
Jul 7, 2002
Loveland, Colorado
I got an engine built by a local machine shop and I went down to pick it up and one of the things they charged me for was "kiss big end of rods." I am wondering if someone can tell me wtf this means. I talked to AMS and they were thinking it probably meant pin fitting the rods. But on my receipt it already has a charge for pin fitting the rods. So if anyone knows what it means please let me know.
Thanks
I've never heard of anybody referring to it as a kiss, but they are most likely talking about honing the big end. Eagle's have pretty poor machining from the factory and a lot of builders correct it before they install them. I would call them on Monday and see if that's what they meant.
I don't know how accurate this is but it came up on a web search for "connecting rod kiss":
http://www.rddane.com/page/connrod.htm
Maybe someone with more mechanical knowledge can shed some light.
[Ooo, that'd better not be it. A block to limit travel might be.... problematic]
I would assume it was either grinding them for clearancing purposes or for re-honing them as stated above since all new rods should be taken apart, re-torqued, and honed before being installed in the motor. Why don't you just ask them?
Thanks for the replies. More than likely it is legitimate. They are a pretty reputable shop. I just wanted to see if anyone knew exactly what it meant before I questioned their work.
When you do any work to a rod it needs to be rebalanced. Sounds like someone took care of you checking over the rods completely so you should have a good set of rods there.
  • Wanted 6 bolt NT water pipe
    • chrisman287
