what does a stock injector look like.???
1990gsx1781
190
Jun 28, 2008
Lynn, Massachusetts
right now on my 2.0 turbo i have injectors in there with blue tops in there in my middle console i have 4 injectors that have a grey top which one is stock? my car keep stalling at a stop so im gonna switch them out ( my car came with the blue ones so im not sure if the grey ones are the stock ones taken out...) thanx i know this is a stupid question
Blue would be the stock injectors as far as the grey injectors i would have to have a better look at them to determine if they are from a late model or some JDM Denso's.
I know the 450s are stock not sure about the grey one though. All the stock injectors turbo i know of are blue. But im not an expert.
Some injectors have a size stamped on the side or a code atleast. And if your car is an automatic it may have had 390cc injectors in it which may be the grey top ones you have and somebody may have put the 450cc injectors in there. If they did and did not change out the ecu for one out of a strait shift model then you would be running rich with the 450cc injectors. Look on the side fo your grey injectors and see if they have a size listed on them.
1g manual 450's= blue top
1g auto 390's= grey top
1g jdm 510's= yellow top
2g 450's= black top
The injectors will have a number on the side of the colored part. The number will have the injector size in it.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
