[RESOLVED] What does a socketed ECU look like?
How to tell if you have an EPROM (which can be socketed):
DSMLink - FAQ - EPROM
You wouldn't be able to tell if you have a socketed ECU without taking it out and opening it up. You can tell you have a socket if you see something between the EPROM chip and the circuit board. You should be able to pull out the EPROM chip easily from the socket.
The first picture is exactly as it states on the sticker - A/C Controller Module.
The second picture looks like the factory amp plug.
I have a 95 so I should have an eprom right? I looked in there, and saw the E on the middle line(thought that was the tell), but i didn't look for the little E on the bottom.
So where do you hook up a laptop for dsm link anyways? Is it the diagnostics port, or should there be an actual socket coming from the ecu?
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
