what do i need to make this turbo work?
peon_slayer
259
34
Oct 6, 2008
grande prairie, AB, Canada
ok i have got myself a holset hx35w turbo i want to put onto my motor that i will be getting in a few weeks, anyway its not flanged to fit the mitsu exhaust mani, i want it to just bolt up. what will i need for this to work? is there an adapter plate or do i just need a different hotside? also what kind of injectors should i go with? i only want to run 18psi till i get better pistons and rods and abuilt head...
BEP (bullseye performance) sells the hotside for Holsets that are flanged for a Mitsu exhaust mani & o2 sensor housing. I thought you had to buy the Holset with the housing but my buddy informed me yesterday that Tim's Turbo's sells them, heres the link to it... Tim's Turbos - Turbo Rebuilding - Stainless Steel Turbine Housing - Mitsubishi Inlet
I would run 880's or bigger if your just going to run pump gas, 1100cc or 1150cc injectors for e85.
I've never ran a Holset but a buddy does and his car peels the ears off my head when he mashes the gas pedal...
:dsm:
You don't nee a built head. just a pair of hks or regrind 272s and at most a smim and exhaust manifold upgrade. The 6bolt block, which you have, can tolerate whatever that hx35 can throw at it; as long as you have a spot on tune. Yes you will need 850 or close for race/pump gasoline. and you will need 1250s or more for e-85.
