What do i do about a p1495 check engine light code? (98 avenger)
99 gst 420a dsm
509
Jan 22, 2003
Turboville, New York
Im getting a CEL code that reads a p1495 which is a LDC solonoid malfunction, just wondering if anyone else has run into this and/or knows how to fix it
P1495 (M) Leak Detection Pump Solenoid Circuit An open or shorted condition detected in the Leak
Thats how it reads.... but that dosent tell me what i need to change to get rid of the CEL....
not the same dtc but similar, maybe it will help
SUBJECT: Misdiagnosed Leak Detection Pump Systems With DTC P1494, P0442, P0455, OR P0456
DATE: Feb. 4, 2000
DISCUSSION:
During evaporative system diagnosis, Leak Detection Pumps have mistakenly been replaced. A thorough inspection for pinched, kinked, or disconnected supply vacuum lines (as currently listed in the Powertrain Diagnostic Procedures) is a critical step in diagnosing DTC P1494 (LDP SW OR MECHANICAL FAULT). Additionally, the other evaporative leak faults (DTC P0442 - SMALL LEAK, P0455 - LARGE LEAK, and P0456 - VERY SMALL LEAK) should have the supply vacuum lines examined for pinches or kinks prior to any LDP component replacement.
The supply vacuum lines should be checked from the engine compartment all the way to the fuel tank, including the LDP and purge system.
NOTE: VERIFY ALL RELATED SUPPLY VACUUM LINE ROUTINGS FOR PINCHES, KINKS, OR DISCONNECTION'S BEFORE REPLACING LDP SYSTEM COMPONENTS.
POLICY: Information Only
simply put... a vaccum link leak. Let the car cool down completely and start it and try to do the "soapy water" technique. Kinda like a boost leak test. It will show leaks unless it is an actual vaccum leak. But check the obvious first of course. Throttle body lines etc..
Good luck, these leaks are a b*^%H to find sometimes. Oh yea if its a leak that is suppose to be a vaccum source sometimes you can spray a little carb or brake clean in the suspicious area and if the motor revs then you can narrow it down a lil.
